i was out n about all that night... forgot 2 post as well, monday arvo bout 3:00, all at erina... spotted 1 black silvia or 32 with no wing n nice mags at the big set of lights... a silver 32 pulling out below the 7/11... n a stock but really nice looking yellow 34 gtt with wing going past the woodport
spotted WLD25T at cardiff yesterday around 3 3.30pm
That thing is always in Cardiff. It just sits in slightly difference spots all the time because it's for sale.
Atleast it looks better than it did. I beleive it had a Veilside kit when it was for sale in a car yard at Edgeworth.
Also I spotted a Grey or Black R33 in Cardiff (Cardiff Toyota Intersection) at around.. 8:00pm-ish.
spotted dark blue 32 at nelson bay today..... only skyline i have seen apart from mine since i been here from sunday.
are there any/many skylines in newcastle??? many ppl look at me like "what type of car are you driving"
the closest car i have seen that looks modified is the police cars, and 1 mirage with an exhaust if that counts, im guessing there isnt much of a car scene in newcastle........
spotted drews okokok 34 gtr with sum cool lookn kid driving it into gossy last night... did i mention he was cool? :D
spotted a cool lookn kid in a 34 gtt pearlescent pearl drift spec machine cruisin round the freeway on saturday night.
Friday night spotted a nice looking white R34 fellowed me from lisarow to wyoming ...... it also sounded nuts
spotted a silver R33 at wyoming
spotted a nice clean white R33 going thought wyong
The white R33 might of been me. I was between Chittaway/Watanobbi a few times friday night.
I spotted a silver r34 gtt on tuggerah straight near autobarn saturday
Also a black r32 gtst at wyong on sat.
was it white with an ex gate?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
