Spotted dark grey s2 33gtst with sau sticker on rear windscreen at shell servo at gorokan this arvo, nice driving you fkn co(khead. U nearly hit my gf while u were showing everyone how tuff u are. Burnouts in a servo are u retarded?
spotted E.k at lake haven heading towards charmhaven ............ spotted a silver r33 just comming out of charlestown about 11.30 ..... i tooted and wake out the sunroof but it was too late
Spotted hempy, his misses, and OKOKOK drewboy at erina fair tonight.. i high beamed hempy in the eyes and honked at drew/dv11sh in the forester
ah wondered why a forester tooted us lol
Cruised with gunmetal grey 33 - SKYLIN from Swansea along the freeway, on my way home from work the other day.
Dropped back & pulled thru traffic to catch up. Friggin thrust bearing started chuckin it in even more, so Im holding you responsible.
spotted a dark grey R35 going down kariong this morning bout 730!!! ohhhh so hot... got a wave off a green P plater in a white series 2 r33 this arvo at gosford 2
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
