YEAH IM HERE!!!!! hahaha yeah its off the roads still. all i need is the drivers side guard and its done ...... ill post a pic of it atm in its dusty state :cool: just so you can all spot my skyline in my garage seeing as its been there for 2 months
This is how the skyline is going at the moment for you guys that haven't seen it out for a while. Ive got all new parts and all i need is the surround for the front bar indicator on drivers side, also front driver side fender.
the rest is all there except underneath the hood. Its been pushed back about 8cm but i have the radiator support
Spotted!
LOL
spotted 2 R33s yesterday morring around a 11am
both on the freeway
white R33 serise 1 non turbo * southbound*
gun metal gray serise 2 turbo * northbound*
Spotted andrews and jadas car.. at their house.. and drews car too...
also spotted sam916 at ourimbah this arvo.. was in the gf's car so u wouldnt have reconised me!
Spotted MY33RM at Glendale Macca's, very nice car.
Yeah this thing is mint.
It's a 40th Anniversary one, purple isn't it? Or am I thinking of a different car...
Edited by -Jimmy-
spotted a r33 4 door on manns road west gosford at 10am, was a girl driver and she let me cross at the zebra crossing unlike everyone else!
THANK YOU!!!
Not sure of the 40th Anniversary bit and it was more of a maroon.. but it was mint
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
