Hey everyone.
I have just moved from Kiama on the south coast up to Newie. So suprised to see that other skylines actually wave to you. Feel so loved lol
I followed a black 33 GTS thru town the other night, can't remember too many details and a silver 33 GTS waved like crazy at me near Raymond Terrace??
Saw a nice 32 GTR at the lights on the highway near Raymond Terrace (?) we were both at the front of a red light.
Aaaaaaand i've been pulled over a fair bit by the po po. Is this normal up here? I don't get a 2nd look in Syd...
Oh and if u see me keep waving lol MYR-33E - Silver GTS-T :P
Hey fellow coasties,
I need some work done on the r33 could you please PM me info on good workshops or which ones to avoid in the gosford area? Thanks heaps
Also spotted/drove passed a accident on manns road a week back red r33 front end damage, bad luck man hope you and the car are ok.
cheers Rich
central coast car service is pretty good, its near the racecourse, in West Gossy, dont know the street but...???icon6.gif
Ha ha ha yeah it is normal for newcastle to be pulled up on a regular basis with skylines mind you i have had a good run with them if you dont take it in town on thursday nights and stuff like that you should be fine
Could be me man i drive to nissan at wyong every morning from 7:30 for work. I didnt see you but :geek:
I saw a black r35 this arvo at kariong traffic lights
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
