Silver 34 GT on TE37 SLs in woy woy today
Thats my mate matt. Its his new car bought from a guy in Queensland last week (hence the QLD plates on it still).
Spotted a white R33 gts-t with a shit bodykit in gosford this arvo, and a sweet looking gunmetal 32 GTR northbound on the freeway just past twin servos
Spotted a white R32 (not sure if gts/t/r? too dark to see) a bit over an hour ago, turning from hugh st onto the pacific highway at merewether. Also saw about 4 different silver R33's in the bottom level carpark of charlestown square between 6 and 7pm - one of them had a dark boot lid and a really nice exhaust note :)
Got my license back on Monday after a pretty lengthy time off.. 8 months in total, was very happy to finally win my appeal in the district court.
Anyway, also got my epa noise test passed (got a notice in the mail not long after loosing my license) Had to get a standard catback and put the standard cat converter back on. Also needed to get a airbox as i bought it with a pod, and remove the boost controller. I was lucky to get away with the dump pipe i had. After it finally passed (86db) i needed to get a pink slip. The bloke at this joint was a pain in the arse. I honestly didnt notice the horn not working or the number plate light out, so fair enough... but they were fixed at the auto electrician (which is part of the business) so i was expecting a pass. Then the bloke notices the key comes out of the ignition while running... fail. Lucky i got one from the toy shop and my old boy fitted it and had it passed the next day.
Seriously though, i was really surprised that he knocked it back over that, i have had them let me off with stuff like that numerous times. Will not go back to that painful prick.
Anyway, sorry for the rant.. but im all back on the road now! :)
  • 5 weeks later...
Not as yet. Well they are in the car, only sitting on the back seat though. Trying to source another subframe as thanks to low ride height, a tow ball and tongue on the road and 90km/h, Mine is a bit farked.
How did you go with yours?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
