I own a white V sedan on coilovers and deep dish mesh style wheels and P plates. . I've seen your driving can't remember where but I seen you parked in Darby street a few times. You drive a very nice car, jealous as. I'll root and wave next time I see you.
thats funny as.thats a great pic up line lol but if that was face to face i think she might have slapped ya lol. :wub:
im on a smart phone so i was meant to say toot........
Spotted a black 32 at the top of Myall Rd this morning
Also a white 34 with black mags very dark tint and GTR wing along Thomas St and Newcastle Rd this arvo. Sounded like it was running a lot of boost as well
And a black 34 atthe lights at Tighes Hill Tafe this afternoon
Hi Guys havent really posted on here before even though I have been a member for years lol, just wanted to say Hi, I own a silver V35 350GT might see it around Wallsend/Jesomond way mostly, if you see me say Hi!
Spotted a white 33 along Brisbane water drive this morning
Had a body kit from hell and looked and sounded sweet
Also spotted this car, gave a wave, and as you said sounded very nice
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
