Im still going to have to get mine passed, but last time it tested at 102db, and its gotta be under 90! If i remember rightly, the test is at 4800 rpm for my gtst, so not hitting boost is kinda scary, but im not sure if it will really boost in neutral with no load, anyone tried it?
When i got done i had a mazda 3 muffler fitted to my r33 and it passed just drop your boost down to stock and you will pass but yeah it will go like shit with the muffler on
^^^ did u get done in the foreshore thursday nite??
also newy muffler service will make ya up a bolt on
muffler to get u passed just dont hit boost lol
No I dont cut laps. I was 2 mins from home and the timewasters pulled me over for an RBT.
Does anyone have a stock compliance cat s13,r32 or r33 GTST GTR,Stag or Ceffie are all the same.
Thanks mate, will give him a call. My old man took the skyline over to the epa test at redhead the first time, and he told dad the cannon would need to be replaced regardless because it was rusted to the shit house. I spoke to my guitarist on the weekend (who i bought it off) and he thought it was strange because the system isnt very old (3" 5zigen) Got to pulling it off on the weekend, and the thing is completely fine. Rather weird.
Probley trying to make money out of ya but your better off getting a large oval muffler like a magnaflow or ect will get less attention that way
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
