what cam gear settings would you recomened to run using rb20det exhaust cam in r32 rb25de head??
inlet cams seem to be identical
but if changing exhaust cam is as easy as swapping them over and dialling them in with adjustable cam gear then why not..
have both silvertop rb20det and r32 rb25de heads sitting next to each other..
https://www.sau.com.au/forums/topic/240965-general-build-questions/
Hey guys, im currently building a RB30/25 DET, will be turbo'n it after ive done the internals, atm ive stripped the block down and have had the cylinders honed, what would you suggest i do to the crank, rods, pistons, etc. want it to be able to handle 14psi ish. if not more depending on what has to be done.
Cheers, Sam
As I mentioned in previous post. The Rb20det cam has the same duration and lift as the rb25de but the centerline is more suitable for N/A. However the rb25de cam appears to do fairly well with the 3ltr.
If you drop the rb20det cam in to the rb25de head you will drop power compared to the rb25de smaller cam as the centerline of the rb20det cam is not suited to the rb30det.
So.. Drop a set of adj. cams gears on to it.
But honestly.. I wouldn't bother. The rb25de cams appear to do fairly well. Wait until you throw a set of cams at it then bother.
14psi doesn't mean much..
What turbo? what power goal?
I was thinking of a bit power for more top end, so a bigish turbo (dont know specifics of it yet) as for its going to be daily driven so nothing crazy =p. power goal prolly round the 300-400whp or upwards, dont wana spend to much on internals, first time working on one of these motors. not sure of its potential. just want some ideas of what to do.
Cheers, sam
Not really suitable for this thread but typically if your sticking with the std exh. manifold don't go any bigger than a gt3076r .82.
If your going to go an aftermarket exh manifold GT35r or larger. :)
Stock internals handle quite a bit of power (400-500rwhp) Its rev's/missed shifts that kills them.
I have a generic engine building question, probably easy an one for you guys but it's my first engine build so I'm trying to get my research done.
I've got a standard 30 block, crank and rods, all are in good condition and don't require grinding. I also have a full set of standard size ACL race bearings.
Questions is, if I simply put them in and torque to spec the clearances will most likely be all over the place and no good?
And, if the clearances aren't right do I have to get the crank ground to match the bearings?
I'm more than likely just going to hand the bottom end components to an engine builder and have them do it, I'd just like to know the process.
Cheers all
Get the crank ground for oversize bearings just to be on the safe side..
I didn't to start with and turned out the crank had some massive end-float and it munched out my thrust washers and nearly ended in big tears.
For the $120 to get the crank machined and the ~$80 for .010 oversize bearings, I should have done it to begin with and I wouldn't have had to pull the motor out again!
Bubba...
As the crank is nitreded from factory its best not to grind the crank if possible.
If the motor had massive end-float its the assembler that didn't do his job ensuring everything was in spec when the motor was pulled down.
I went with King bearings bimetals which use an oversized thrust so a better alternative than machining the crank completely with oversized bearings.
So far so good 90,000km's and counting. :D
It's because we just slapped it together with standard spec bearings. Had it reground, fresh bearings (I run NDC with no dramas, japs ftw), new oil pump and have done another 10,000 odd (hard) km with no dramas :D
Edited by bubba
Hi all, im about to put the head onto my 30 and i need to sort all of the bottom end stuff before i end up having to squeeze past manifolds to do so. Anywho, Im running a front mounted oil cooler which looks like the pic below at the block end. Now, the sandwhich plate provides an easy and simple way to tap into your oil flow to run gauges, so what do i do with the factory sensor? Can i block it with a bolt? Im not fussed if the factory oil gauge in the cluster doesnt go but without it will my oil light stay on? And last but not least, where does the factory sensor thread into the block?
Any advice would be mint.
Cheers
Factory sensor threads into the block on the same side as the oil filter but further towards the back of the engine. I put a T here and ran the sender for my aftermarket gauge off the same spot with the stock sender still installed.
Awesome , cheers for that. I think il run th factory gauge and then just the gauges off the sandwich plate. Using a N1 pump anyone know what sort of oil pressure i should be running?
I intend on reassembling the engine myself, but I don't want to buy standard size bearings then assemble it and find the tolerances are out.
Will the engine machinists be able to tell me whether I'll need standard or oversize bearings when I get the crank linished?
I'm running an N1 pump and I see 100psi on cold start (I also belief the relief spring is 100psi), at normal operating temp I see 10-20psi at idle depending on oil temp. 40psi ~2000rpm, 60psi ~3000rpm, 80psi ~4000rpm and from about 5000rpm onwards it's hitting 100psi.
Machininst will be able to measure it and tell you if it needs to be ground.
  • 1 year later...
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
