Hey guys/girls,
I got some unwanted items from my birthday have a look, there all listed below..
First up a Nokia N70 in pretty good condition, the phone comes with a fully charged battery so you can use it right away.. lol.. A wall charger and a 64MB multimedia card oh yeah, it has a nismo wallpaper too.. :wacko:
I've had this phone for almost 1 year now an it works as good as the day I got it..
Its available for local pick up from Brighton in Sydney for $130 and it can also be posted to you it for a little under $10..
Next up is 2x Pioneer sub boxes, with the pioneer logo embroided on the back, they are missing the wire terminal thingy, but I'm pretty sure you can get these from jay car for $3.00.. They are for 12" subs and are in pretty good condition i.e. no rips or cracks.. Looking for $20 each or both for $30.. Pick up is preferred for these boxes as they are a lil bit heavy..
Next on the hit list – I have 2 watches, (seems like they were on everyone's mind for present ideas.. lol..) first watch is a mambo one, this has a leather band with a black dial.. umm, gives you the time in 12 hour and 24 hour the date and the day.. $60 + post.. the next watch is guess, its stainless steel with a brownish dial, again this watch gives you the time in 12 hour and 24 hour the date and the day.. $120
If your interested in these items you can contact me via pm or on 0425 324 062
Cheers,
Mark
post-49013-1224574074_thumb.jpg post-49013-1224574091_thumb.jpg post-49013-1224574108_thumb.jpg post-49013-1224574117_thumb.jpg post-49013-1224574133_thumb.jpg post-49013-1224574150_thumb.jpg post-49013-1224574186_thumb.jpg post-49013-1224574205_thumb.jpg post-49013-1224574229_thumb.jpg post-49013-1224574238_thumb.jpg
https://www.sau.com.au/forums/topic/241107-stuff-for-sale/
Guess watch sale fell through, all items still up for grabs..
Open to reasonable offers even swaps with somthing that may be of interest such as r33 5 piece floor mats, stock r33 wheels, clear r33 side indicators etc..
thanks
https://www.sau.com.au/forums/topic/241107-stuff-for-sale/#findComment-4217970
  • 3 weeks later...
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
