Have a set of Genuine gmax enigma wheels/tyres for sale or swap... *F 18-265/40 *R 18-275/40
Come with next to new tyres.. (1000kms) ive just had them sprayed in a fresh coat of silver as i reakon it looks better then the factory shadow.. asking $1600 or will trade with a set of 33/34 gtr wheels and tyres, i will put in extra for 34 wheels, as for 33 wheels im not real worried as long as ther in good condition...
also have standard 33' vspec carbon finish dash cluster and centre console gauges.. asking $300 for both,
4x Greddy gauges.. all 60mm electronic warning/peak white/green..
oil temp-
water temp-
A/F ratio-
oil pressure-
All brand new in boxs, $ 280ea
Brand new momo trek r (Black) - $250
Standard v-spec suspension - $300 ono
Will have more stuff to post up soon as i finish cleaning out my spare room....
pm me if your interested in anything...
Cheers..
https://www.sau.com.au/forums/topic/241612-wheels-cluster-etc/
few pics up here,,, hks sq valves i have also.. a lil dirty just need a little metal polish, be good as new.. asking $300 for both or $150ea comes with adaptors,, came off my Gtr
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
