Just need some advice on cutting about 10mm off the bottom of my bike's fender without destroying the paint with excessive heat.
It constantly bottoms out going down kerbs and needs a trim.......where it's marked roughly with a silver marker.
I originally used a small angle grinder with a 1mm disc to cut & shape the fender then a dremmel to clean it up..........but that was before paint.
The black will be easy to fix, but I don't want heat to lift the airbrushed stuff.
https://www.sau.com.au/forums/topic/241755-help-on-how-to-cut-a-bike-fender/
deffently take it to a pro pete. then if something goes wrong youve got someone else to blame :rofl:
only way i can think of though that would get you a decent finish would be the angle grinder. maybe do a few seconds of grinding and dip it in water to get it cool to try and save the paint? theres not a whole lot to cut off so you might get away with it? also try calling someone like 69 customs, they might be able to give you some pointers on cutting airbrushed things?
but really, i wouldnt go off something i or anyone off here says. id really go to someone whos done this before haha :D
If you do it bit by bit with a 1mm disc on an angle grinder you shouldn't damage it too much (the heat will want to stay in the smaller end anyway). Having said that I'm pretty sure you would need to get some of the air brush touched up. I'm a fourth year metal fabricator and have cut a bit of powder coated/ two pack stuff but never any airbrush..
PM Craved (you will find him in the fabrication section), he seems to be a wealth of knowledge.
Pete,
Ive done this kinda work before ... many years ago.
Mask up the line you want to cut along, then mark it up with a texta. Find the finest, finest cutting tool you can (maybe in your case a fine cutting blade on a grinder and/or dremel). Peal off the tape when you are done as soon as you can, because water and masking tape can leave the tape glue behind (and some of the paper). You will more than likely require a small touch up around the cutting edge.
:rofl:
If you need a good bloke for the touch up ... try Daniel Stone Paint and Panel at Hackham. He's an old riding buddy of mine and hes done work to my Stageas. He's done body work for custom Harleys as well as jap crap bikes :D Tell him ruby sent you and hell look after you.
Edited by RubyRS4
yeah touch up of the edge after I can handle cause it'll be in the black area.......as long as the heat doesn't lift the paint further into the airbrush area I reckon I should be OK..........I hope :rofl:
yeah touch up of the edge after I can handle cause it'll be in the black area.......as long as the heat doesn't lift the paint further into the airbrush area I reckon I should be OK..........I hope :D
You'll be fine then.
Use the tape to eliminate any potnetial chipping or burring of the paint.
Use the finest cutting edge/blade you can and take your time. It is a piece of cake.
:rofl:
If you need a good bloke for the touch up ... try Daniel Stone Paint and Panel at Hackham. He's an old riding buddy of mine and hes done work to my Stageas. He's done body work for custom Harleys as well as jap crap bikes :( Tell him ruby sent you and hell look after you.
+1 he did the paint on my GTR rims.
Maybe try and run some water over it when your making the cut with a grinder it will help keep the metal nice and cool while cutting.
If you want to be sure not to lift the paint, use a file.
Sure it will take a while but there will be no heat buildup, and if you file from the paint side (apply tape along the finish line to protect from acidents/mistakes) into the fender you should have minimal paint damage.
alright pete i didn't read all of this post but mut some masking tape on the fender draw your line on top of the tape and cut it with the 1mm disc just let it cool a bit before cutting all the way through, ive seen it done and its worked but yeah you might want to go and see a professional good luck either way.
cheers... michael
I wonder how a tungsten bit on the die grinder would go?
That's what I would go with. Perhaps try and use an air hacksaw for the bulk of it (minimal heat) then u could just die grind it for a smooth finish....
Troy from Nightmare Designs is giving me a hand to cut it with a paper thin disc and running water tomorrow.
Check out his website and see if you recognize any bikes..........he's been crowned the best bike painter in the country in 2007 at the nationals (Bike Week) on the Gold Coast.
yeah I might even stick a wet sponge underneath as I'm cutting........any volunteers to hold the sponge :)
Just take it easy pete,slowly is always the key,you know bikes are like woman,like roo said mark up with tape etc,use smallest blade possible and just go slow,it wont heat up that much then,need a hand let me know
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
