for sale are a set of 4 5Zigen FN01R-C's in gloss black with the machine polished lip - also come with the genuine 5Zigen carbon fibre looking centre caps
were originally bought to put onto my S14, however were too wide so a new direction was needed
i imported these rims myself from the USA and cost me over $2000 for them landed
i am looking for a quick sale of $1800 ono
these rims have never been driven on, they did have tyres put on them but i have taken them off as ill need them for the new rims i have purchased
i have been told these are a perfect offset (17x10 +25) for a GTR or a widebodied skyline or S13/180sx...
as far as i am aware there arent too many of this type of rim in australia as 5Zigen Australia seems to be non existent here, so grab yourself an awesome set of rare rims for you pride and joy
i am located in the lower blue mountains about 10-15 mins away from penrith...this sale is pick up only
https://www.sau.com.au/forums/topic/241820-set-of-4-5zigen-fn01r-c/
are these genuine 5zigen??
the only reason i ask is because i have a set of these in mat black and they have 5zigen stamped into them not Fn01r-c.
i thought they only stamed 5zigen on them???
im not saying this is true just curious because i havent seen them like this.
if they are this is a good price brand new from 5zigen these are worth close to 3 grand.
if i didnt have some already id be interested cause they look tough as on my 33.
good luck with the sale though.
thanks mate...yeah they are genuine 5zigen bought from 5zigen international
i got them in from the usa as it was cheaper than buying them from japan due to the dollar situation when i got them...
if i had of got them from 5zigen japan i think from memory it would have cost me about $2700 so i got them from 5zigen usa and ended up costing me around $2100 landed...
Edited by R32_GTS-4
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
