  • Replies 100
na, I was thinking the guy that started a similar thread not long ago that had a so called cop (Hot Fuzz) respond to it
a stated at the start i am new to this whole import/performance thing, so please excuse my out look.
and no i was'nt on here b4 with a differnt name.
its ok sweet, welcome anyway to the home of SAU SA where.............. i should stop now but welcome.
but to us this is a very funny topic
cheer for the welcome. and the only reason i posted this topic is to get a bit of thought from others about the subject. many ppl complain about anti hoon laws and police harassment but noone wants to stand up and say we need more than one place to go a month...... like i said just testing the waters. :) chose the wrong subject but......
they wont do it but you can try andtry but it will fall on deaf ears your best bet would be to go see klem and ask for more track days and with enough people that want more he might open it 2 time pr month cause he does love his money
good luck
good luck
how many ppl would be up for that. from what i understand most track days have limits on the amount of cars, and they book out really quick. if there were more days open would it minimise the dick heads on the streets .... i think it would, that may cause less police fines for all of us!!
i think Clem needs to re-surface the track podgy old bastas.... yesm. Welcome Aboard Mick
valiant idea buy yeah councils don't want to listen if they get us all off the street they loose revenue
they really don't care about safety like they would have to general public think
its a pitty all import owners are tarnished with the same brush. it sux a bit cause drifting is one of the fastest growing sports in australia ( the world for that matter) it would be nice if some of the local parliment members got on board for us.... they would get my vote :)
:) this is funny :rofl: it will never happen not while there is mallala and the cops have hoon laws :thumbsup:
:rofl:
Will never happen. EOI does not = numbers.
You keep beating that dead horse ... you'll end up beating your head against a wall. There is a new motorsport park in the works. In a few years we might have more opportunity. But right now? ... nope.
create a new park open it up after hours, $20 entry, cops will just put defect stations out the front! we are all labeled, undoing a lable of imports being hooons will never happen, your trying to fight through a council, when the gov(popo) will jsut destroy it at the end of the day!
like ppl have said bud WELCOME
on a bad note theres realistically no hope of this happening, just think if 1 driver loses the car into a couple hundred ppl...
i even think getting more track days will be a push, due to consistent numbers of ppl the way it is now clem knows that itll be pretty much full every even if he bumps it up to 2 nights per month theres a high possiblity of the cars spreading out over the 2 events and not being filled and therefore not being viable.
gazanats was on the weekend so we may only be a few months away from A.I.R opening up for drift prac days again keep that in mind!
well there is lala! the streets are for the public and it shouldn't be closed off for something like drifting especially when there's a venue/controlled environment for it already!
if you don't agree then tough bickies because that's the way it is!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
