  • Replies 78
Umm, i think theres a guy on here that knows the R34 Screens inside and out.. Chris Rogers or something.
Look for one of the mods, EUG he knows the contact details for Chris :ninja:
He'll be able to help you either fix it, or bring it to an additional use :P
MRXTCZ
only if they let me :P
to teh OP:
does it work - IE TV function comes up. navi function comes up (both are useless here but that how I'm determining if yours works or not.)
or do you have a blue screen of death on it?
if it works - yes we can do something with it.
i love that popup screen! dont get many cars factory fitted with something like that specially japs...
ive hooked up a dvd player on mine and it works perfectly
and its so simple to do it only took an audio/electrical noob like me 20mins to get it working :)
thanks eveyone, i'm located in sydney at the moment it's running an after market unit, i know it's unlikely to get the GPS work in Aust, however all i was hoping is the get the screen working with the nissan unit or an after market one.
Hey Chris would you be able to give me a qoute, as i only pruchased the car like a day ago, i'm a little short in cash. I would like to make sure i have enought to paid ya.
Cheers
:ermm:
Cheers
ok . screen with a DVD unit attached to it (assuming you do not have one) $500 or so.
  • 1 month later...
  • 3 months later...
Hi all, i have managed to pop the screen the pic are display below, dose it mean my LCD is work? and another thing why dose it pop up by itself i'm unable to control it with the with the "OPEN/CLOSED" button, sometime when i start the car it pop up, but most of the time it dosen't.
I got the Xanavi and know quite a lot about them .............. don't do anything rash like ripping it out..........lol...........the screen does not always come up when you turn ignition on or when you insert and play a CD - thats the first 2 myths to dispel - you can pm me if you want...............
some pics of mine working attached
  • 4 weeks later...
Hey mate,
Thats great, how did you get it to work?
The one on my r34 is completely dead, and I cant read Japanese but have pressed all the buttons anyway hoping for some life...but nothing.
Did you get the sat nav and tv going or are you only using it for playing cd/dvd's.
Cheers
David.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
