When : Sunday 9th November 2003. 9/11/2003.
Time : 5:00pm - 9:00pm
Venue : Mt Cotton Driver Training Centre, Mt Cotton (right on the southern edge of brisbane)
Cost : $87.50
As per the previous Skidpan Day thread, we have 12 spots available.
4 hours of sideways action on a small track covered in deisel and water, with professional instructors to help you get it down pat.
All Roadworthy and Registered cars are welcome.
If you have any questions, please refer to the previous skidpan thread in the QLD forum.
If you 100% want to come, please let me know here, as I have to reserve the date ASAP, its taken me weeks to get this date available.
To pay for your spot, deposit $87.50 into my bank account, the details of which I will give to you if you PM me, or give me cash in person. There are a number of people who have attended previously who are 99% in, so be quick.
Feel free to PM me with any questions also, and remember, please only reply to this thread if you are telling me you are coming.
https://www.sau.com.au/forums/topic/24248-skidpan-day/
  • Replies 86
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
