  • Replies 40
Posted Images
its actually Chris Milton of adelaide engine developments, and yes he has just meta-laxed an n1 block and heads, pistons ,rods etc? for me and assembled it to formula1 tolerances, and he has told me i can rev it to 11000rpm it is an rb26 still and produce around 1100hp. all was rather cheap as i am good friends with his son Sam.below is a photo
oh the spl t51 should be ok or i may have to look at a t88 but i dont want too much lag.,.....
i wholly recommend chris milton as an engine builder
chris and sam know their shit, they just finished my N1 motor, good for 1100kw.
thats a s#&tload of grunt! Is it for track, drag or.......... street?? :P
on a side note, i'm aiming for a reliable 600-700hp
I was planning on using the tomei sump baffle kit, wanting the best protection for the motor.
I've read on here that some members use an extended sump with baffles, should I be doing the same ? Or is this just overkill?
no definately go the baffle and also get a tomei oil restrictor fitted to the block just some extra insurance rb's dont EVER like being starved of bearing oil. they hold alot of oil in the heads when revved hard.
F1's rev to 20,000 rpm.
51's will still have plenty of lag on a 2.6.........did you consider going 2.8 or even 3.0 litre, more cubes = less lag.
what bottom end and sump setup you running that can handle 1500hp?
yes i did consider an rb30 but i want it to scream, i will most probably settle for a Garrett 3037 pro(No smaller) thats about 800hp with 80mm gates ,my r34 gtr has hks gt-rs' and that pulled 343kw on willal's dyno but i cant rev it too hard 8500rpm on standard motor with 270 cams and injectors, power fc and boost kit with z32 Afm's . with my 32gtr I want heaps of mid range all the way to 11grand, i wonder what that will feel like on mallala's twisty turn 1. in a 1200kg r32 GTR, i spose the motor might last a little while longer with less power ,but you're right the 51's will be lag monsters, its really a tough choice, any suggestions?
dry sump for sure.
Edited by ax53b70p25
dry sump for sure.
yep, check this............unless you're interested in straight out drag racing alone, this may be a better solution for the street over a 51 or especially an 88, lol
Monster Twin Setup
thanks, will call them monday.
Not sure, but some quotes i've been given were astronomical!
What price is astronomical?? Has the engine actually given up yet...
Also consider putting a sump baffle in and the oil restictor in the head like the others said.
Have they told you what brand bearings,pistons,rods they like to use in the quotes?
I would source all your own parts like dangerman 4 said..and would want to see them going in the engine.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
