found the fuel pump sitting under my desk at work.....
so items still for sale:
33 gtr fuel pump = $85 delivered
std dump pipes = $50 delivered
stabiliser bars = $80 delivered
std 33 gtr suspension = $130 delivered
std twin bov with piping = $130 delivered or 70 each delivered.
think that's it......
blow off valves sold pending payment
33 gtr fuel pump = $70 delivered
300 for front pipes and cat back std exhaust. pickup only.
Edited by tk80
suspension sold
almost all gone.....last few things:
stabiliser bars = $70 delivered
You got R33 GTR Catalytic Converter for sale? or just front pipe and cat back exhaust?
Is the Stock GTR Cat converter 3"?
hey mate
i've got the full exhaust....from dump pipes to rear muffler.
i'm not going to separate at the moment.....someone will probably buy for compliancing reasons.
don't think it's that big.....would have to measure.
  • 3 weeks later...
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
