Guys, there's a big cruise planned for Sunday 16th. SCC - Skyline Charity Cruise. will be approx 100 skylines heading out for a great day!!
see the events section for details and/or the Sticky thread above
Yeah i'd love to go to that but i don't think my car will be fixed by then. I crashed it and it needs like a lot of parts replaced and its getting a complete respray.
Dude how long have you had it? like a month. what did you crash into in your non turbo skyline?.....Oh yeah anytime i can get off and a cruise is happening expect a visit from me I am always wanting to meet other drivers and see what mods they have done to there cars.
Edited by RandomHero83
Yeah sweet, once your set put an ad in the events section tho...
PS> I know your in Albany Creek, I saw you the other day when I was on my bike... :yucky:
hmm well you got me there.. where was my wave then.. how am i suppose to know its you on your bike.. :P
Yeah i've had it for around about that long, 2 months or something. The back and side of it crashed into trees as it was spinning out, the rest is fine.
I was driving home and it was raining real heavy and theres this big peice of shit roundabout (used to be my favourite until now) that i don't even really know what happened. I was going around it slowly since it was wet, and as i was coming out my car just started sliding and so i tried straightening it but yeah ended up spinning out and crashing it. Apparently i accelerated out too fast but oh well, lesson learnt.
But trust me, i'm incredibily unlucky. As my car was in a ditch i was watching angrily as all the other drivers were going around faster than me and not losing control.
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
