its there mate
it just doesn't vent during gear changes as the throttle body doesn't close.
if your car is auto, try accelerating with the gearstick in gear 1 and watch the boost rise. then just release the accelerator and listen...
its still effective in preventing backflow through the turbo (compressor surge) as this can happen regardless of transmission style.
Waz.
wouldnt it sounds real real poxy if u got an aftermarket one which vents into the atmosphere for the whole pppppsssshhhhh sound. i thought u would have to accelerate and then realease ur foot for the whole GEAR CHANGE EFFECT SOUND?
am i right or wrong?
Yeh sorry guys i was talking bout an aftermarket Blow Off Valve cause i wasnt that "whoosh" sound... so it still goes allright then?
Also all, i hear this sound on silvia s15's and some gts-t's, its a spooling noise with a fluttering at the conclusion of this spooling, i have heard its got something to do with the pluming or something, that the gas is bouncing in the pipes, hence the butterfly/fluttering noise, so my question is...how do i do this? what is it? and is it bad for the car? as in turbo,engine whatever...
thanks once again.
Fluttering = bad longterm
All that is is the compressed air flowing back on to the blades of the turbo, at high RPM these blades are moving really fast...
It wont destroy a turbo.... yes it does sound cool, but over time this will weaken the turbo. If you want to make this noise..... get a aftermarket BOV (adjustable) and tighten it right up so the spring hardly moves (open's) and then you will hear the sound. You might have to run higher than stock boost tho....
nickg,
The standard BOV can have the psssht noise if you put a screw in the small air bleed on the underside of the factory BOV. If you have a pod filter the noise will be reasonably loud and the best thing is the cops can't ping you for it.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
