Hello All,
I just have a quick question, because after going through the search engine it has only expanded my uncertainty...
I am looking at buying a Vl Calais with an rb26dett conversion in it. It is an R33 GTR engine. (not sure whether that would make any difference). Anyway I live in Tasmania and the seller is in Qld. He has been very helpful and seemingly genuine in his comments, giving me any info i want and not needing to think about any answers. So i am not 100% sure but 90% sure that he is telling me the truth about what he is saying, either that or he is an extremely quick thinker....
Now to my question.... He has said that there is a ticking sound coming from the head (he is 99%) sure that its coming from the head. He said that last weekend he has changed the spark plugs which were fouled and the tick is not there on idle, and then it is there through the rev range... I would like some input on what it could be in your opinion. I mean after reading the search engine topics it could be Lifters, valves, and many other things. so i am not after a direct answer. Just if someone has had something like this before...
Also if it was to come from the bottom end... correct me if im wrong but i will be looking at a total rebuild correct????
Any suggestions would be muchly appreciated
I must just also say that i have been told that it is definitely a tick and not a knock...
Kind regards
--Ben
https://www.sau.com.au/forums/topic/243531-ticking-me-off/
Best thing you can do is get a full mechanical inspection done by a reputable workshop with experience with an RB26.
If the seller is genuine he should have no problem with having to take it to get the car inspected.
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4243966
Hello All,
Kind regards
--Ben
Where is he located? I might be able to organise a visit for a bit of a listen.
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244023
He has absolutely no problem with me doing this... I just dont know anyone in QLD... any suggestions??? i have run up about 5 or 6 mobile mechanics in qld and they all sound pretty hopeless... all of them want to do a full roadworthy inspection and this is something that i dont really want because i know that the car isnt roadworthy, due to no locks and minor things. also in a preview of what a roadworthy inspection consists of 3/4 of it are to do with things other than the engine... i want someone to only focus on the engine. due to the fact that this car i supposed to be for at least the next year....
can anyone suggest someone in QLD that would be good for this?? the car is located in ipswich.... (not sure how far this is fromn bris
Kind regards
--Ben
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244026
Kind regards
--Ben
I'll be in Ipswich on Saturday afternoon/night. Half the skyline QLD club will be around that area too if you want a mass inspection :P
More than happy to have a look on my way through. My number is 0407 111 229
I'm off to work now so won't read any reply til tonight. Cya
Cheers, Daniel
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244042
I'll be in Ipswich on Saturday afternoon/night. Half the skyline QLD club will be around that area too if you want a mass inspection :teehee:
Cheers, Daniel
Dan will be at my place in Ipswich on saturday. He is your man. Hook him up with details and we'll gitrdone dude. :P
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244085
Yeah....
I have just spoken to Daniel... I will organise him to have a look at it and will send him the needed info about the car tomorrow.... THANKS DANIEL... when im up i will need your address and set up up with something (a carton or some cash for your trouble)...
I am still open to any suggestions from anyone that wants to post them of what they think it might be....
BIG SMILE :teehee:
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244128
he runs on scotch :P
Just out of interest what sorta mods has this thing got?
WEll i can only say what i have been told. This is what i believe.
Fuel pump
FMIC
5 core radiator
the fuel rail looks like it has been modified so maybe injectors and fuel rail
the turbos are N1's (i think)
hks air pods
hks AFM's
maybe cams (no idea)
internally i have no idea and the engine has not been taken apart by the current owner so he doesnt know either.
Custom 2 piece tail shaft
vn LSD diff
GTR 32 gearbox (i assume that it is internals in the RB30 box because to the best of my knowledge the bell housing of the GTR's doesnt fit in the vl's transmission tunnel.
That could also mean that it has an aftermarket clutch... maybe...
exhaust 3'
and no after market management system that i am aware of... i must stress that this car is a current project that is not quite finished... so some mods may have been taken off or even not done yet... and this is only what i assume and i do not know if these are all the mods on the car.... hope that this is enough detail :)
other than that
Group A ss wheels
Aero body kit
VS commodore dash - with all aircon and pwer steering working
gauges - tacho - boost - water - oil and something else
racing seats
calais rear seats
thats it
--Ben
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244500
dunno if you know this but all the rb26 equiped cars ive ever heard all have a little tick in them up top
shims or something?
Yep. In my experience this is the case.
Especially if you've changed your lifters etc.
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244844
shims should not be noisy. the common ticking noisy in RB26 is injectors. they have very noisy injectors. easy way to test. at idle, give the car a rev and sharply lift of the gas. just as you lift off and as the revs fall the noise should completely stop for a very brief moment (as the injectors all shut for a split second).
as for changing lifters etc... I can't think of any GTR engines off the top of my head who have changed the lifters? why? they are not a service or wear item really and nothing you can really do to upgrade them. they are just a piece of solid metal, like a tiny bucket.
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4244872
only a idea but i heard somewhere that the bigger injectors will sometimes tick when operating?? dont hold me to this!
read the post above yours.
Also, I am fairly sure it will have standard injectors as the factory ECU is still fitted according to this guy
https://www.sau.com.au/forums/topic/243531-ticking-me-off/#findComment-4245325
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
