Hey people,
I have a set of O.Z racing rims for sale, as the title saids there 18 x 9 and they are off an r32 gtr.
They are a lightweight 3 piece rim made in italy that weigh approx 13-14kg each
Not sure about the offset..
Bad thing is that two of them are buckled and can be repaired but ive since put stockies back on my car
i dont have time to fix them and need the extra cash. There abit like the nismo Lm's style.
all rims have minor scratches since they were made in 1995.
They come with 3 rubber tyres - bridgestone PlayZ's PZ-01's 245/40's with ok rubber.
The other rubber tyre is prob rooted i think not sure.
Check my gallery to see what theyd look like on a skyline or look @ my avatar.
Asking $500
Located near Brighton Sydney, pickup only.
>>> Call 0421 835 965 <<<<< dont be cheap and pm me if you wana know something CALLLLLLL!
https://www.sau.com.au/forums/topic/243567-18-x-9-oz-racing-lightweight-rims/
  • 2 months later...
Gathered by the various markings on the rims with 28 im guessing their +28 offset.
They were a perfect fit on a gtr as can be seen in my gallery.
and if you want the rims you call or contact ME on 0421 835 965
no time wasters they're cheap enough.
and remember ---->>>>>
ive clearly stated that 2 rims need repairing, dont ask me what,
come and see and judge for yourself as you can never tell 100% with photos.
they are ideally being sold as a PAIR of rims with the option to repair the other 2.
they are located in sans souci - sydney
Edited by SideOn
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
