Hey all,
I have had what seems to be some pretty serious electrical problems with my R32 GTR after recently purchasing it.
OK so problem occured when I was just driving to work normally and my wipers just turned on at abnormally fast speeds without touching the wiper switch. After this I heard some clicking and noises under dash and almost all electrics stopped working. This was my dash, clock, stereo, wipers, all lights, blinkers, power windows etc. The only things I could see still working were electronic boost controller, turbo timer and power fc as car was still driving fine.
So I got it to the auto elec straight away and he has told me that the main problem was my alternator and about 10 blown fuses in the engine bay and interior fuse box. After replacing alternator and all blown fuses the auto elec has told me that clicking noises are still coming from below the dash and it is still blowing the power wdw, wiper and heater fan fuses, all others seem to be OK.
So I am really hoping someone on here can shed some light on the problem as my car is going on 2 weeks at auto elec (he claims he is a man down).
I was also hoping someone could provide me with or a link to a complete wiring diagram with fusebox circuits for a 1989 R32 GTR.
Any help is greatly appreciated!!!!!!
Thanks,
Mitch.
Edited by sinstr
https://www.sau.com.au/forums/topic/243593-r32-gtr-electrical-problems/
Clicky Here!!
Try that link...
Download the one you need and away you go. :cheers:
Excellent, that was what Im after, thanks alot for your help!
And thanks godzl1975 but im all sorted now :D
Also if anyone else has any insight into my problems please feel free to post up.
Cheers,
Mitch.
Hey,
Well the auto elec is on his way to getting my car sorted after finding many f*cked relays from the surge my alternator produced.
There are a couple of things I am chasing that I am hoping someone can help me with as the alternator surge fried them too.
Im after a door lock timer (so the auto elec called it) It has something to do with door locks and power windows. It has the numbers '2845189971' on it. It is an 8 pin relay that is located below the right kick panel.
If anyone has any ideas where I can get one of these or if there is an alternate relay to use please post up.
I am also after but not as urgently, a fan speed resistor located underneath the glovebox.
Please post up if you have any ideas as I wanna get my car back! :blink:
Cheers,
Mitch.
Edited by sinstr
Hey,
Well I have located the parts needed for my car and have finally got my car back from the auto elec after 3 weeks.
BUT I am still having a coupla probs, judging by the interest in this thread I doubt I will get any feedback, but its worth a shot.
Basically my 4wd (have 2wd/4wd controller installed), Tacho (aftermarket impul full dash unit), clock (no biggie) and 3 gauges still arent working. Hopefully someone can give me some info on where to look to get these problems resolved, particularly 4wd and tacho.
I suppose first thing to try would be to remove aftermarket 4wd/2wd controller? How do I go about doing this? Tacho, clock and gauges i dunno where to start but any info is good!
Cheers,
Mitch.
  • 7 months later...
Does anyone know what is connected to the "MAIN" fuse ? I swapped a RB25 in my R32 and even when I remove the key, something is still taking power. I removed the "MAIN" fuse and it stops.
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
