realistically this thread should have been originally posted in the forced induction thread me thinks.
or maybe even again, not posted at all and maybe the dude that posted this thread should just go see a mechanic or engine builder and sit down with them and talk to them about it. that way they will get a much better idea of what is involved as well as costs involved.
  • Replies 46
OK, to start with I hope the above figure is a turbo figure cause you will never see that from an n/a motor, I doubt you would see that with nitrous and I have a 26/30 n/a setup in my 31.
Of course it will be a turbo motor lol, sorry should of said that. Probably get it built then put twin GTRS's on it and that should bump up the power to make over 400. Gonna be costly tho :P
I remember reading quite some time ago that the atessa AWD system in the R33 GTS4's is *NOT* the same as that in a GTR... from what I remember reading it was slightly more simplistic in nature... ie. didn't have the full feature set that the GTR's did (sensors and what not). I may be wrong, but I do remember reading a fairly in depth article on it. In contrast, I know the R32 GTS4's is the same as the 32 GTR's...
gts-4, gtr have exact same system no doubt.
bottom line for this thread wont be giving you answers about turbo like a turbo forum, anyone trying to make 300kw+ for a non turbo is going to have to spend the stupidest amount of money on the car and yes making it a gts-t would help if you want to make it a bit of a drifter car but maybe moving the thread would save you the hassle rather than deleting it because you already know its going to have to be engineered if you use any other skyline engine other than a gts-4 one or do the internals either way let the turbo people wave there turbo magic on you.
ok i seeeeeeeeeee. :D
big turbo fixes stuff haha, still you mentioned drift and i doubt the engine will hold up with all that pressure. The money will need to be poured in, in the long run.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
