Item:
Racing Hart CP-F Tune Wheels
N/A
Condition:
Very Good
Price:
$2,000.00 FIRM pickup
(can deliver to Sydney area for cost of fuel)
To Fit: (What car)
any 5 x 114.3 stud pattern
Tuggerah, NSW 2259
Contact:
PM
Comments:
I am selling a set of Racing Hart CP-F Tune, 5 x 114.3 stud pattern, 18 x 9.5 with 17 offset. These wheels are FORGED, 2 piece light weight wheels, very rare and discontinued, hard to find a set of these wheels in this condition, sit perfect on R32GTR, no rubbing at all even on the full lock. *no tyres come with this sale*
Thanks for looking
Cheers
https://www.sau.com.au/forums/topic/244188-racing-hart-cp-f-tune-18-x-95-17/
I think its reasonable considering you have had absolutely no serious offers except for the two i have made.
And that $1000 will determine whether you sell them this week or not.
I'll go a little bit better and offer $1200 if you can drop it off to a local busfreight depot.
Hopefully this offer isn't insulting.
Hi mate,,
it's still abit too low but i'm didn't think it's insulting on ur offer.. i would say $1K offer or below are insulting !!
its a bad market at the moment subie its hard moving parts :(
maybe try swapping them for parts your after or something
yeah, market's very bad,, i would love to swap them for ur rims but too bad you've already sold it
Thanks anyway
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
