Hi Fellow Stagea drivers,
As per the topic, I need to run my power cable for my Amp but cannot find anywhere to run the power cable through the firewall into the cabin.... I want to do it neat and dont want to butcher anything by trail and error.....
If anyone could take a pic of their engine bay where they've run it through that would be really helpfull.....
If I need to drill a new hole... where is safest??
Cheers! :D
the most important question is...where is your amp located?
My amp is under my passenger seat and got the power wire running through the ac pipe grommet (so I have long power wire running across the engine bay to the battery
Cheers! :D
that may help a bit
Amp is in the boot bolted to the sub box.... I want to run the power cable and RCA's under the carpet/seats to the back....
Put an amp and sub in mine on Sunday.
I pierced through the huge loom grommet on the drivers side (under some little relay thing in engine bay) with a screwdriver from the inside, then pushed the power cable through the hole I'd made with a coathanger and pulled the wire through. Comes out near the kick panel on the floor and ran it alongside the standard loom under the carpet.
The spot in the photo Mike has posted is the best place - pull your plastic inner wheel arch liner off a bit and you'll find a hole where most of the wiring loom goes into the cabin from the engine bay. Get a piece of wire (like a straightened coat hanger or similar) and feed it through from inside the arch and into the cabin, you should see or feel it come through right near your accelerator pedal.
Thanks guys,
Hopefully one of these arvo's i'll have time to give it a shot!! :D
Cheers! :P
Hey mate,
I’ve had this setup in my car for about 2 years now.
2 gauge wire from battery
Then using cable ties :domokun:
Run your wire next to the fuel filter and down the fuel line. (Fuel line doesn't get hot, so don’t worry about that.)
When u follow the fuel line down, under your back seat (Driver Side) is a rubber grommet, make a hole in the rubber grommet so that the wire can come into the car.
Then you can feed the wire to the amp which is in the back??
hope that helps...
PS. If u want pics, let me know.
Hey mate,
I've had this setup in my car for about 2 years now.
Then using cable ties :(
Run your wire next to the fuel filter and down the fuel line. (Fuel line doesn't get hot, so don't worry about that.)
hope that helps...
+1 This is what we had to do to my brothers S2, he runs 0 gauge wire which is massive.
If you do go this rout make sure to use decent quality cable ties.
Hey mate,
Then using cable ties :laugh:
hope that helps...
Very Very interesting!!!! :rofl:
No issues with damage on the wire being outside...??
I guess you could run it through a plastic tube or something to protect it.....
Pics would be great if possible!! :banana:
P.S. I know about the power and RCA's not being near eachother.... Cheers anyways pipster11!
Very Very interesting!!!! :)
Pics would be great if possible!! :rofl:
From front to back. Sorry about the bad pics...
if your going to damage this wire, your going to damage your fuel line 1st. :P
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
