hi im gonna get my r32 resprayed at work soon and was wondering if anyone who has a universal rubber around their windscreen can show us a pic
i know the genuine windscreen rubbers from nissan cost a lot!! and yeh universal will be hell cheaper
would just like to see some pics thanks
Any windscreen place should have universal seals. Mine were replaced early this year when i had the car resprayed and there was no way i was paying for a genuine set from nissan.
Havent had any problem with them lifting or anything so far.
  • 12 years later...
On 11/15/2008 at 9:11 PM, Mr Cali said:
Sorry it took so long mate, been busy.
Here's the pic of the rubbers for you.
Any idea where I could get my hands on these? There are way to many options for 'window rubbers' and their not the best style.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
