  • 1 month later...
  • 1 month later...
Don you have any info about replacebility of Y34 brake hoses?
Is it possible to replace the stock hoses with reinforced without much work?
I havnt needed to do this for my Y34 but I would imagine it isnt any different to other cars. Take the brake lines off and take them to a decent brake shop, in Adelaide Power Brakes on North East Road are good. They will make you a direct replacement braided line within a few hours.
Hey guys!
can anyone help me with what sort of offset I can go with rims? I want 20" with some nice dish but I dont know whats going to fit.... I dont want to have to touch the bodywork if I can help it thanks :)
I have 8.5 +20 on the front and 9 +14 on the rear. Mine is stock height and at the front they are perfect but at the rear they stick out about 4-5mm If the car was lower they would tuck in a bit.
Aisha the rims I sourced Kermit are:
19x9 +20F
19x10+20R
Which to be fair when removing the width factor it works out to be similar fitment dimension to the poster above me..
While it sounds like it is pretty aggressive fitment its truly not... These cars seem to REally swallow rims..
Kermit is riding on lowered bilstein spring at the moment but he wants to space out his rears a little he reckons...
So that gives you a fair idea..
But it's all up to you...
I reckon your car would look excellent in some reverse mounted work varianza T1S :)
Edited by Mr Eps
HOLY CRAP AISHA CHECK THESE OUT!!!!!
21 inches!!!!!
9.5JJ +38
10.5JJ +18
PCD: 114.3
5 holes
Reverse mounted custom finished Work Varianza!!! TWENTY ONES!!!!
Lil Jon would be jealous. They might seem full on but honestly you would teach a lot of these boys about gangster fitment if you scooped them up for a decent price..
http://www.importmonster.com.au/view?url=http://page19.auctions.yahoo.co.jp/jp/auction/x162879258&thumb=http://f1.auctions.c.yimg.jp/f31batchimg.auctions.yahoo.co.jp/users/0/7/3/7/powergroup_osaka-thumb-1302188025379355.jpg&title=WORK%20T1S%20VARIANZA%2021%209%205%2010%205%20IS%20GS
Edited by Mr Eps
hey rowan im in love with the eurolines import monster has for sale on the aussie shop area but my limit was $2200 including tyres... dont think its gonna happen :( lol i shall keep searching i would like a little bling and lotsa dish im a fan of multispokes too... +38 on the front?? are you sure they would fit? I mean kermits are +20 and he only has 10mm of brake clearance?!
You need to up your limit - the only 20s you're gonna get for that money are Bob Jane pieces of shit. Keep an eye on Import Monster and snag some cheap through Yahoo Auctions. 19s are fine for your purposes too ;)
I need help with what sort of rims I should get for the gloria!! I want 20", i want bling and I want dish, but these dont all seem to come together..... anyway can I please have your opinions on the rims pictured (attached)??? smile.gif
In order:
Perfect
Shit
Shit
Shit
Barely passable
  • 1 year later...
  • 10 months later...
  • 6 months later...
thread diggs
anyone know who still can comply Y34's?
word on the street is the 2 workshops in brisbane arent doing it and theres one place in Melb who can, but has suffered from some misfortune and may not be able to do it for a while...
any more info out there?
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
