Have a few items for sale, sold my other R33 so cleaned out a few parts before sale to get agreed price.
HKS EVC III Electronic boost controller. Perfect cond, works great. comes with manual. $300
Genuine Nissan Skyline R33 Floor mats front and rear, perfect cond no stains what so ever. $100
Genuine Ganador electric (blue lense) mirrors for R33GTST $300 obo
can post all parts, items located in QLD 4680
If it has no cracked, motor still works & the colour is nissan black I'll take it! Pls PM me you bank details.
Can you also let me know what exactly is the blue Lense? Any close pics?
Edited by Blitz_R33
mirrors sold, evc google it for pic's, it didnt sell with my car. thats the reason for sale, pretty sure it says that in the add.
I'll take pic's of the mats when i get time, it's a hassle. as i said they are all in perfect cond, no rips or stains and well just perfect. i brought them off phat lavish on here. anyways, cheers.
Mirrors back up for sale due to time wasters. . Mats are sold, well.. the rear ones are but i might keep the front set for my 180. Yes mate, the drivers side was in mint cond, quite rare really. Boost controller sold.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
