OZ Racing light weight 17x9 +24 suited to gtr but may go okay on gts-t. minor scatches and minor gutter rash. coming off a r33 gtr which only clear brembo's by about 2mm. would sit perfect on r32 gtr. 3 piece wheels made in italy with silver cenrtes and polished rim. clear coat has flaked off the outer rim but still polish up well. includes falken azenis st115 (made in japan) tyres 245/45/17 with about 80% tread.
can take more pics once they are off the car if requested.
$1500 pick up from shailer park.
also selling 4 15mm bolt on spacers with locating rings if you want even wider offset.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
