E . O . I: 6 And 8 Piston Big Brake Packages
Hi all,
Im very keen on getting a big brake upgrade for my R33, the supplier ive been in talks with told me if i can get 5 kits ordered for a group buy the saving on each kit would be very substantial.
So here is the info:
6 and 8 piston calipers
330mm,356mm and a massive 380mm rotors
Rotors can be either grooved or slotted
Kit contains:
Two front 2 piece rotors
Two 6 or 8 piston calipers
Braided brake lines
Dog bones
Pads
You can choose from silver,red and blue.
Slotted version
Grooved version( very similar if not the same as this)
Prices will be between $1699 and $2199 delivered.
Good news is these kits are interchangeable with AP items and come with a 6 month warranty.
If you are interested please feel free to ask questions and ill do my best to answer.
:banana:
does this mean you can use AP pads .?
with the 6 pot kit or 8 pot
so what would it cost me to get a 6pot kit delivered to Adelaide 5013 please im interested as the car goes in this thursday to get worked and ill need bigger brakes after its done.
Yes its suited for AP pads.
Your kit will be $1799 Delivered.
Is everything in this kit ADR compliant?
Im not quite sure ill have to ask. Though im sure most aftermarket performance brake products on the market today are not.
cool bear with me i just need to decide 356mm or bigger but ill get back to you asap when ive made my mind up
You are limited to your wheel size.
330mm for 17 inch, 356mm 18 inch and 380mm 19 inch wheels.
how long does this gb offer go for i wont have the $$$ for a couple off weeks took the car to get rebuilt with a new motor yesterday
but anyway put me down for 6piston 330mm rotor for my r33 4 door ill try to get the cash together abit quicker to you as you need payments first.
cheers
Allan
Dave, 380mm and 18" works, just need the right offset and spoke design, eg driftek 18" should clear 380mm discs.
Well, i hope so! Ive measured them up against my brakes and they seem fine, mine are AP 6 fronts 380mm, rears are AP 335mm
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
