before you say do a search, i have found somethings out but not all to my satisfactory.
I wanting to put R32 gtr guards on my gts-t. These are obviously wider, and then my genuine gtr bar will then fit properly, but from my understanding i will need gtr indicators as well. Someone also sed i will need gtr guard liners as well, but that sed are they referring to the flexible plastic parts that sit infront of the tyre to stop spray from going everywhere? One side has already fallen off if that is the part, so guess i wont need to worry bout that.
Anything else ill need to fit these? if i have no skirts on or the stock gtst ones (NOT mspec), then these guards will fit yes? Then if i want to fit gtr skirts on the car, will these fit up fine? what about the rear part of the skirt as the rear of a gtst is less wider than a gtr at that poiint from what i understand.
Anything anyone can add will be appreciated!
PS does anyone have any pictures of gtr front guards on a gtst?! send away!
Cheers, David
Edited by R32Abuser
https://www.sau.com.au/forums/topic/244877-r32-gtr-front-guards-on-gtst/
Hey mate. Front gtr guards on a gtst will require the indicators as they are different. Will look heaps better with a gtr bonnet and grill but not needed. Guard liners are different but again, not needed.
My guess would be that gtst skirts would not fit at the front and the gtr skirts would have a gap at the rear. But personally i havent tried this. It may be possible to fit them.
I think the main problem will be how the rear of the car will look obviously less tuff and more pussy in comparison to the front. But should still look better overall.
Good luck with it mate :ph34r:
  • 7 months later...
I was wondering if anyone has modified 32 GTR side skirts to fit on a GTST or GTS R32. The fact the GTR has wider front and rear guages means there is a gap, can this be filled in by modifiying the skirts? Anyone done it?
Cheers
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
