Greetings..
My brother's Bike Was Stolen from his garage on Saturday night In Reservoir along with his laptop.
The Bike is a black Suzuki GSXR-750 2007 model.
Their was no exhaust Fitted at the time. Red race Tape was put around the wheels, Their is also a Dark colored Decal of a woman on the Tank and side of the Bike.
The Bike was Insured along with the Laptop.
Small reward offered If Located.
Cheers.
https://www.sau.com.au/forums/topic/245174-stolen-motorbike-gsxr750/
as far as i know we are the only people that flash the ecu and train key codes for the immobilisers on bikes.....we do this for lost keys as a new ecu is well over 3k for some models...I always ask to see reg papers ect to prove the ownership....Chances are the bikes been knicked for parts,but you never know so send me the VIN if you like and if something comes in will let you know
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
