hey guys i am in melb and about 2 months ago i brought an r32 gtst that came with a canary and no rego....
im not wanting to sell the car but if i can get around 10k for it ill sell it straight away the only thing that needs to be done to it is it now need to be taken down and be tested for sound pollution i also need to put the rear tyres on it that i brought last week but if i was to sell it ill do that straight away..
now about the car!
it was built in november 1992 its black in colour manual 5 speed has 152000kms on the clock, T3 hyflow turbo, front mount intercooler, turbo back 3 1/2" exhaust sys, it has been remaped by dr drift it got 159rwkw on 11psi... i have lost the dyno sheet but i do have another copy in the car from when it was 1st tuned with a stock exhuast and pulled 146rwkw dont ask why it was tuned with a stock exhuast i have no idea why!!!!
its got 18" rims on it there 5 spoke akukzas and there like a silver polished kind of metal when i got the car the interior was pink with thalaw stitched in to it i have dyed the back seats with black dye and put seat covers on the front if anyone is interested i can throw in r33 stock front seats...
hrrm i also have a sard fuel regulator that i hav not put in yet... all that is needed now is a z32 air meter, gtr injectors,gtr resistor pack and a cam gear for the car to pull over 250rwkw....
i might be able to help out with the z32 airflow meter if someone wants the car...
as i said ealrier i just seeing if i can fetch around 10k for the car if not ill just keep it finish off the mods and see if i can get a little more later if pics are need i will post them just ask!!! thanks all for looking!!!
https://www.sau.com.au/forums/topic/245328-r32-gtst/
been trying to upload these pics but it just wont happen for me if anyone need them i can email the pics.... this is a very good looking r32....
all reasonable offers shall be looked at thanks guys
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4270410
hey buddy sending the pics through to you now also i forgot that it has a bosch 040 fuel pump... and a pioneer mast unit but the dvd player and tv for the master unit is at pioneer being repaired... as we speak.... the master unit controlls all tv channels dvds and playstation!
can you email me pics thnx mate :down:
[email protected]
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4274987
hey Madskidz thankyou for adding those pics
no worries mate, if you got anymore you want to add...email em my way & i'll chuck em up for u!
as you can see from these pics, the car has been clearly looked after :P gl with the sale m8
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4277176
hey guys i really need to get rid of this car if the car sells in the next 3 days ill let it go for $7300 cash other wise i will start to advertise else i cant afford to keep this car much longer all that is needed for the epa now is an airbox put in or intercooler removed... i can probs get hold of a standard airbox if the car goes asap.... i will deliver interstate at buyers cost... also i forgot to add earlier i still got the standard series 2 spolier to go with the car aswell!!!!!
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4305246
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
