hey guys i am in melb and about 2 months ago i brought an r32 gtst that came with a canary and no rego....
im not wanting to sell the car but if i can get around 10k for it ill sell it straight away the only thing that needs to be done to it is it now need to be taken down and be tested for sound pollution i also need to put the rear tyres on it that i brought last week but if i was to sell it ill do that straight away..
now about the car!
it was built in november 1992 its black in colour manual 5 speed has 152000kms on the clock, T3 hyflow turbo, front mount intercooler, turbo back 3 1/2" exhaust sys, it has been remaped by dr drift it got 159rwkw on 11psi... i have lost the dyno sheet but i do have another copy in the car from when it was 1st tuned with a stock exhuast and pulled 146rwkw dont ask why it was tuned with a stock exhuast i have no idea why!!!!
its got 18" rims on it there 5 spoke akukzas and there like a silver polished kind of metal when i got the car the interior was pink with thalaw stitched in to it i have dyed the back seats with black dye and put seat covers on the front if anyone is interested i can throw in r33 stock front seats...
hrrm i also have a sard fuel regulator that i hav not put in yet... all that is needed now is a z32 air meter, gtr injectors,gtr resistor pack and a cam gear for the car to pull over 250rwkw....
i might be able to help out with the z32 airflow meter if someone wants the car...
as i said ealrier i just seeing if i can fetch around 10k for the car if not ill just keep it finish off the mods and see if i can get a little more later if pics are need i will post them just ask!!! thanks all for looking!!!
https://www.sau.com.au/forums/topic/245328-r32-gtst/
been trying to upload these pics but it just wont happen for me if anyone need them i can email the pics.... this is a very good looking r32....
all reasonable offers shall be looked at thanks guys
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4270410
hey buddy sending the pics through to you now also i forgot that it has a bosch 040 fuel pump... and a pioneer mast unit but the dvd player and tv for the master unit is at pioneer being repaired... as we speak.... the master unit controlls all tv channels dvds and playstation!
can you email me pics thnx mate :down:
[email protected]
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4274987
hey Madskidz thankyou for adding those pics
no worries mate, if you got anymore you want to add...email em my way & i'll chuck em up for u!
as you can see from these pics, the car has been clearly looked after :P gl with the sale m8
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4277176
hey guys i really need to get rid of this car if the car sells in the next 3 days ill let it go for $7300 cash other wise i will start to advertise else i cant afford to keep this car much longer all that is needed for the epa now is an airbox put in or intercooler removed... i can probs get hold of a standard airbox if the car goes asap.... i will deliver interstate at buyers cost... also i forgot to add earlier i still got the standard series 2 spolier to go with the car aswell!!!!!
https://www.sau.com.au/forums/topic/245328-r32-gtst/#findComment-4305246
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
