Heaps N Heaps Of Parts Nismo 2 Way, Safety21 Full Cage, Tein Coilovers, Hks 2535, Recaro Pair, Whiteline Sway Bars, Arc, Apexi, Greddy, Momo Ect Ect
  • Replies 63
Hi, I'm interested in the "R32 GTST Brand new Whiteline/Selby Adjustable Front Sway Bar $200 - brand new not installed - comes with bar links and bushes".
I was just wondering if it would fit on a R33 GTST?
how good a condition is the radiator in as in fin damage?
in terms of cooling, its better then perfect. takes ages to warm up in the morning compared to stock, but has never, not once even come remotely close 2 being hot... even after hills runs or drift sessions.
it could, but im not 100% sure.
Rear strut bar sold
FMIC + piping not for sale anymore
oil catch can sold
Side skirts sold
Intake pipe sold
Water pump sold
Edited by DjeMz
yeah as far as im aware all skyline seats bolt up...
before these i had a pair or 33 gtsts n they bolted up fine
cheers
thanks andrew, enjoy :D
Hi mate interested in the airbox, just wondering about the filter itself, how easy are they to get hold of or can they be interchanged with other brand name filters?
Thanks.
Thanks.
hey mate
you can either buy another filter from arc and i have heard you can just measure up the filter on there, go to super cheap or auto barn and order a panel filter to fit them measurements. The filter on there looks pretty normal, not worn or anything.
cheers
hey mate interested in turbo. Any shaft play? Willing to post?
hey mate
very very very minimal shaft play (probably not even worth mentioning). yeah if you keen i can ship it and take a vid of the car running/warming up... blows 0 smoke, makes 0 squealing noise, makes good power reliably
cheers
what colour is it ?
and wheres the damage ?
and its a real gtr bonnet yea?
would u be able to upload a pic of it
cause im in fawkner
preety close
i can come anytime and pick it up off ya
Rear strut bar sold
oil catch can sold
Side skirts sold
Intake pipe sold
Water pump sold
7 point cage sold
sounds like your thermostat is old and stuck open
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
    • I know on some cars it's explicitly endorsed in the service manual but a lot of them it isn't which is what gives me pause. I know a lot of cars also have you jack up the car by the radiator core support which is a lot easier to get to than some crazy deep section of the front subframe. I'm just reluctant to find out if any of that is really safe to do if not listed in the service manual. The FK8 has even the R-chassis beat in this regard, the front subframe jack point is almost fully behind the front tires and is surprisingly recessed into the car.
    • I've been doing it for longer then I can remember and on pretty much every car I've owned without any issues.  Jack on a tow point (or under the rear diff), jack stands under control arms/other beefy suspension component is my go to if I'm not using the quick jack.
