hi guys
i have recently found that there is a misfire in my r33 gts-t at about 6500rpm under load in first gear runing at 6psi
when i run it at 10psi the problem gets worse and does it at about 4000, then 5000 then 6000 rpm.
it feels very similar to when you hit the rev limiter only you feel it the once.
the only mods are k&n pod filter with cai, turbo smart boost controler (swichable) and i have only just put a full 3'' exhaust on this week.
anyone know what this problem could be or any ideas?
https://www.sau.com.au/forums/topic/24544-big-mis-in-r33/
ok Robo ive done the search and what u say about the safc sounds good. but if the fuel dumping is my problem could this be fixed by simply turning the boost down?
how much would it cost me for a safc and a good tune?
i do want to put in an apexi power fc in my car soon, so would i be wasting my time and money buying the safc? also my car is an auto so i dont know if i can use an apexi power fc?????????
https://www.sau.com.au/forums/topic/24544-big-mis-in-r33/#findComment-524723
i have the exact same prob and so do 2 of my other mates. i am getting mine fixed atm and one of my other mates has just had his done. it has to do with the coil packs being stuffed/cracked. the cover that is over the top of the coil packs in the 33's isnt exactly the best when it comes to ventilation of heat. i am getting bosch coil packs put in. and i run with the cover off in the mean time. the bosch packs don't fit under the factory cover, so they get mounted externally of the cover and are alot cheaper. :)
https://www.sau.com.au/forums/topic/24544-big-mis-in-r33/#findComment-524850
robo
thanks for the info. i turned my boost down to 6 psi and the problem isnt as bad, but it is still there. it missfires at 6500 rpm, just before gear change. if it still does it with the boost down to 6psi this leads me to think it may be something else because its only just started to do it also.(within the last week)
or do you think i should just get a safc.
https://www.sau.com.au/forums/topic/24544-big-mis-in-r33/#findComment-526296
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
