I've got up for sale two pairs of Prada sunglasses for MEN.
Purchased them from a mate without really looking at them and decided they just don't suit my face, I'm very picky with my sunglasses so my loss is your gain.
Have no idea what the model numbers are but they are 100% genuine. For those sunglass fiends out there, the photos will verify that the styles do exist.
Photos:
Price: $250.00 each or $400.00 for both
Location: North Shore - pickup or delivery via post anywhere in Australia.
What you get...
* Sunglasses
* Genuine Prada Case
* Genuine Prada Cleaning Cloth
* Prada Certificate of Authenticity
Will make for a great X'Mas present, and it definitely beats paying full price at the retailers...
https://www.sau.com.au/forums/topic/245521-2-pairs-of-genuine-prada-sunglasses/
  • 3 weeks later...
i love the way you have to make note they are for men. f**k fashion like that is so f**king gay, you'd never know they were mens glasses unless someone told you.
