Driver Dynamics Beginners Drift Day Sandown Saturday 17th January 2009
  • Replies 147
Posted Images
so i'm guesing this is gonna happen in the car park? how much track time each?
is this the same as a cams event so needed is a day's cam's license and gear would be required such as adr helmet long sleeve's and closed footwear ?
We're running it on the circuit, you dont need a cams or assa license to participate in any of our days, you also dont need a helmet, or any special mods to your car.
This is not a full on drift day, and is not suited to experienced drifters.
well if u block, by putting a chunk of wood or something there, the release lever so it'll always release the hand brake when ur foot's off it shud work.
There's a release lever?
Quote vsute
"HEy wayne I will try and pop down on the day .
See how its all going .
Cheers
Tim"
Sorry mate , we cant have spectators.
not sure on booking but can you show up and pay on the day?
Sorry you cant show up on the day, if you'd like to come you'll need to book
CRAZY
i am in for sure without a doubt thou more info would be nice
bit worried about sandown those barriers arent exactly soft
will there be a driver in the car with us beginners as too teach?
anyone can go sideways but control and carrying a corner is a different bunch of potatoes
i will wait to see if my car will still be up for it closer to the day before i book but im there....
Does your car have to be registered? I just booked, but my car is not registered, plan on trailering it there. It's all safe and fine, but thought I better check! Maybe should've checked before booking, but I got carried away haha :)
It needs to be registered or in registerable condition
CRAZY
..er I'm a little confused here, does this mean you're coming or ur not coming ????
Yep, it's registerable condition, no problem. The only changes since it was last registered are just that the interior is stripped out, and it has a roll cage.
Cool :)
Kev
that means as long as my car comes out of the mechanics this week with no dramas after changing my turbo over ill be coming for sure.
i rang up today bout it all apparently they split the track up into 3 sections where its safe to "drift"
should be an awsome day there is only 10 spots left too so be quick i am penciled in for the day and i can pay for it in the near future....
:) haha must be cause i sweet talked the sexy voiced girl on the phone
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
