there is a screw in the transmission pan (just under the gearbox, same kinda deal as engine oil)
undo that let it drain out.
mine took something like 4.3 litres after changing valvebodies.
you prob wont need that much.
put car in (N) and fill it up through the dipstick hole, just behind left hand side rocker cover.
do it bit by bit checking your levels. you need to get it right, too much or too little will make your transmission do shithouse things.
basic idea for you :)
