Hey guys,
As some of you may know, my RB26 died last week. It's at the workshop, pending investigation into the engine failure.
Ok, that aside, I need help finding a cheap car for a few months. If anyone is or knows of anyone selling a really cheap car (and I mean really cheap, just to get around in) please let me know! I need one urgently to get to and from work (this weekend would be good :down:), so I need it to have registration, even if it's just a few months left on it.
I'm in South Yarra if that helps, I'd pretty much buy anything that is working, and will work for a few more months.
My budget is ~$1k, $1.5k maximum.
I hope it is OK to post this request in here.
Thanks guys, all help appreciated!
https://www.sau.com.au/forums/topic/245805-help-needed/
the guy across the street has a 80s pulsar Q, auto, good interior, ok white exterior
has rego left on it, needs tyres, oil leak sealed up, engine steam clean and wipers for roady
He's after $550.... if it was manual i would of bought it for a bush basher!
located in ringwood/Wantirna (30km from city)
very reliable...
I also know of a MINT MR30 Skyline with rego and roady, real classic, Ti 'luxury' for the 1984
$3000 ready to go....
https://www.sau.com.au/forums/topic/245805-help-needed/#findComment-4285125
go the above posted car...
r31's never die, and can be had for ~1200bux with 12months reg, then 100buck rwc :sick:
my mrs has a mark3 supra with new trans and pads/rotors with a little bit of reg if you want to spend a bit more ~3k i think
https://www.sau.com.au/forums/topic/245805-help-needed/#findComment-4285642
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
