Hey guys,
As some of you may know, my RB26 died last week. It's at the workshop, pending investigation into the engine failure.
Ok, that aside, I need help finding a cheap car for a few months. If anyone is or knows of anyone selling a really cheap car (and I mean really cheap, just to get around in) please let me know! I need one urgently to get to and from work (this weekend would be good :down:), so I need it to have registration, even if it's just a few months left on it.
I'm in South Yarra if that helps, I'd pretty much buy anything that is working, and will work for a few more months.
My budget is ~$1k, $1.5k maximum.
I hope it is OK to post this request in here.
Thanks guys, all help appreciated!
https://www.sau.com.au/forums/topic/245805-help-needed/
the guy across the street has a 80s pulsar Q, auto, good interior, ok white exterior
has rego left on it, needs tyres, oil leak sealed up, engine steam clean and wipers for roady
He's after $550.... if it was manual i would of bought it for a bush basher!
located in ringwood/Wantirna (30km from city)
very reliable...
I also know of a MINT MR30 Skyline with rego and roady, real classic, Ti 'luxury' for the 1984
$3000 ready to go....
https://www.sau.com.au/forums/topic/245805-help-needed/#findComment-4285125
go the above posted car...
r31's never die, and can be had for ~1200bux with 12months reg, then 100buck rwc :sick:
my mrs has a mark3 supra with new trans and pads/rotors with a little bit of reg if you want to spend a bit more ~3k i think
https://www.sau.com.au/forums/topic/245805-help-needed/#findComment-4285642
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
