Hey guys anyone who has up graded their dumps to after market just wanted to know quickly is there any difference in noise like does the car sound different ? i know there is hardly any power increase but just wanted to know if it will sound more tuff?
no point bumping when a thread is less than a day old...
Anyhow, little bit more noise... dumps probably not.
I made near enough the power going to stock R33 items as i did when i had trust items on.
Cheers
nissan stagea 116kw very quiet stock exhaust
140.2kw jjr dump/front pipe . xforce cat . 1xforce muffler . xforce rear muffler with twin 3inch tips
power full exhaust yes. sound ... nice RB rumble, be more if only one muffler but being a wagon there will be too much droneing sound
sick thanx guys im really exited to get them on to see what the difference is. If i take my cat off and it is not guttered i got a replacement pipe in my kit and im going to put that on so less restriction cant wait ill update how i go
ok i did it and not to bad you cant hear that much of a change but i took my cat off to see how it went with a replacement pipe and i can feel the difference but i will be returning the cat tonight as it stinks to much and i cant afford a fine but worked out well and looks very nice with chromed pipes
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
