  • Replies 448
Posted Images
down like a clown, charlie brown.
...depending on a few things.
OoOo sounds good...last one was fun..although dave(scandyflick) molested my 32 lol
bah, loved it.
  • 3 weeks later...
i have the star droppers to go with the banner that pk has to go with the pegs that steddy eddy has
to go infront of the display to make the display look superfrikendomino's awsome
speaking of which, we had domino's..we had it for tea tonigh...dam that 8 meats pizza with beam bbq sauce is good!!
pitty the box with the meat inside had dots on it and was soggy....
not really keen on eating from soggy spotty boxes these days, unless iv had a few.....
soz, back on topic.. ill be there for a looksie
and how many pizzas u eat craig..........?????? 1 ,2,3???????
ahah
you get what you pay for with resprays Mitch.
There is always Daniel Stone Spray Painting down at Hackham. He's done work to my Stageas and he does an excellent job for a good price. Runs from a small workshop. Long time riding buddy of mine and a great bloke. :(
There is always Daniel Stone Spray Painting down at Hackham. He's done work to my Stageas and he does an excellent job for a good price. Runs from a small workshop. Long time riding buddy of mine and a great bloke. :)
Might have to give him a call next month, been meaning to get my spoiler and front bar resprayed for a while... if u got a number pls chuck it up, otherwise I'll have to break my laziness and actually use whitepages.com.au
-D
Joe from Pro Finish Custom Painting did my front bar and BoostdR's whole R34, i can vouch for his excellent work and im sure Matt will too. 0411 234 992
2/20 Famechon Cr, Modbury North. less than 100m from Morpowa.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
