  • Replies 448
Posted Images
We're going to be cooked hanging around outside in this weather at SMASA. Very nice.
I was going to drop the Stag off, chat a bit, then f**k off home to my pool less than 5 minutes away ;)
ouch......
thats nasty :);)
Given the heat wave and the fact I don't want heatstroke, I'm doing what I can to cool down. Given my house is a few minutes away, I'll be using my pool frequently. I will however be to and from throughout the day. ;)
Bring ya bathers, I'll see if Tracy doesn't mind visitors, and we'll take it in turns. :) No promises tho.
Edited by RubyRS4
Bring ya bathers, I'll see if Tracy doesn't mind visitors, and we'll take it in turns. ;) No promises tho.
he he tis all good. we will work something out to help us through it.
anyone know if we can get power from anywhere???
if so i might be able to bring a lil fridge.
hey ruby who bout u bring the pool to SMASA instead ;) it will fit in the back of the stag wont it? lol ;)
and dave - no offence and i really mean it - but i do know what the judges are like and i would prefer if all late entrants for the SAU are well, skylines..........like i said no offence to u r anything i just know what the judges are like........
hey ruby who bout u bring the pool to SMASA instead :) it will fit in the back of the stag wont it? lol :P
Hmm, I have a little wading pool I could bring ... but I doubt we'd get an SA Water permit to fill it. ;)
Funny you should mention the above ... I kept the pool kit (in boxes) in the back of the silver Stagea before building it :ermm:
hey ruby who bout u bring the pool to SMASA instead :bunny: it will fit in the back of the stag wont it? lol :D
*shrug*
whatever.
I'll be armed with a water pistol and aint afraid to use it! :ermm:
I'll bring a gazebo + chairs for people to use. Be good if someone else brings another gazebo so we dont need to squeeze under one.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
