  • Replies 448
Posted Images
man I'm getting sick of checking this thread over & over.
The show finished 10 days ago and this thread has already been shut down once.....only reason I re-opened it was at Troy's request to post pics of the show but it seems to be turning into Wasteland again.
I'm in 2 minds at the moment so I'll let it go for a smidge longer to see how it fairs
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
