  • Replies 448
Posted Images
done and done. i know Pete wants to enter too :) and Heslo, cpl of nice gtr's for the display
hopefully pete will :P spoke to luke he said he wont be able to :) and i really wanted his gtr in the display too!
hey all!!
meeting this firday at vilis ok! around 7ish?
ill have entry forms and be collecting payments........ as far as i know they would prefer all entries in by the 12th (so they can organise trophies)
lemme know how u all go
:D
yay! thanks Glenn ur a legend!
ok ive done a small list of those that i have bugged about entering :thumbsup: so far my list is 4 R31's, 5 R32's, 4 R33's and 2 R34's (WTF!)
so... people please......especialy r34 owners....enter....and any one with a stag too!
but yeah if u need to contact me at anytime peoples my number is 0430 18 34 34
if u cant make it friday night please let me know!
best to get it too me if ya can so i can send them all in together :D
just double checking ,
do you have my form and money
(thats if vu handed it over to you instead of him posting the forms he had)
cheer's
Guest
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
