i'm sick of paying $600 for good tyres that are 275 wide, i run gmax enigma rims, and the rears are a killer. so i've decided to stick with something smaller and get even better tyres..... still less than half price of pirellis! so i have my eye on the standard r32 gtst wheels (wheel pic attached) and i was wondering if they can clear the 33 gtst brakes... ANY help would be excellent, cheers!!!!
Slav
https://www.sau.com.au/forums/topic/246213-will-32gtst-rims-fit-a-33gtst/
what size/wide are ur enigmas's? and yes they will fit
enigmas are a 18 x 9.5 rear, wearing 275/35's and fronts are 18 x 8.5's wearing 235/40 if i remember correctly. looking for trade on smaller rims also, as per for sale thread :P thanks for the info dude, helps heaps
slav
u don't need to have 275 35 mate...9.5 can wear a 245 40 tyre pretty happily and wil lcost less ebcause its a common sized tyre...think ur spending too much on tyres that u don't need...or else stop dropping skids lolz
haha, no skids here, just handbrake turns, well that makes me feel better, i dont know how the 245 will sit, the 275's sit pretty flush on the rear. the car does get quite a workout. i track it regularly and semi slick 275's cost me a kidney last time i bought them. anyways, youve opened up a whole new world of tyre choice for me... thanks :wub: all i can do is ---> :P:):wub:
^^ exactly....i mean u could even do 235/40 and it will have just slight stretch...some people on here run 10" wide wheels with 215!! crazy stretch but of course illegal lolz. ur fronts could use 225/40's aswel.
if someone told u to get 275s on ur rears they should be shot. 255 at max. 275s should be fitted on 10"-11"
Edited by jakez88
275's on a 9.5" rim is the correct size.
How do you figure that?
A 9.5" wide rim is roughly 240mm wide in mm, a 275 tyre is 275mm wide..
You'de run something like a 235 or 245 tyre which would fit nicely on the rim, anything bigger than that and it will be baggy
275 is just over kill, what a waste of money
For the price difference from a 235 to a 245 tyre is quiet a jump when your buying a full set, I'd save the extra cash and go with the 235 tyre as your only losing 10mm/5mm on each side which is nothing
245 is probably still a bit over kill, save some more cash and go with 235. That will save you heaps of money as there is a bit of a price jump from 235 to 245
Factory those rims come out with 205 so your not losing anything
You obviously don't know where wheels get measured from :sick:
A 9.5" rim isn't measured from edge to edge, it's measured from where the bead of the tyre sits. for instance a stock R32 gtst rim is 6" wide but the total width of the rim is 7.5". The same goes for diametre. the total diametre of the same rim is just under 17.5" but where the bead of the tyre sits is 16".
So according to your 'figuering' these rims should have a 153 tyre on them................ :)
Nuh man the 245's on my rim sit perfectly, not overkill at all. No stretch and it dosnt hang over the side of the rim. perfect fit. I heard that you probably shouldnt go over 255 on a 9.5 inch rim or it will start to look gay.
Im running 235's on my fronts that are only 8.5 inches wide, also sit perfectly.
i dunno but to me i just wouldn't wanna buy a tyre more than 255 for a 9.5" wheel unless i need to for some reason...doesn't seem right having 265's or 275's hanging over the wheel?
i have 8 up front a 9 in rears...i have 215 45 bridgestones which give slight stretch and 235 45 advan neovas on rear and are perfect if not the slightest stretch.
now if a 235 tyre is hardly stretched on my 9s...on 9.5s i think they'd have a good stretch. 245 should correct the stretch..so anyway in the OP case having a 235 or 245 tyre would be best as it would be cheaper then running anything bigger obviously especially running 275
thats a 275 on a 9", doesnt look "gay" to me.
it also depends on the tyre brand, as those same rims had 235's on them when i got rid of them, and the 8" front looks fine, the 9" rear is stretched a little.
245 on 9.5 " is the legal minimum size. that's what i run and i am definately fan of the look... slight stretch, and legal... just :P
235's are cheaper as they are more common, but it depends on the tyre... bridgestone adrenalins are around 380 a corner in 245/40/18
You obviously don't know where wheels get measured from :blink:
So according to your 'figuering' these rims should have a 153 tyre on them................ :D
lol I know how rims are measured man
but hey if you want to run a 275 tyre on a 9.5" rim go nuts, certainly looks gay to me. Pictures above compliments of Mitch to show how gay
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
