Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
No time for this atm , being banished to Parks v soon .
T04Z uses T series wheels , P trim T04 turbine and T04R compressor .
I'd go with whatever makes the best innitial and mid range - torque wins races .
Spud out , back soon .
The 1.06 housing is going to be far to large for the stuart hillclimbs and the bitumen sprints. Definetely go the .82 on the GT35 if your serious about these events and are set on only one of those options, even that im thinking might not be as resposive as you would want.
i tried telling him about that exhaust housing choice but didnt want to listen by the sounds of it.
no more like
"GT35R is crap, T04z comes on song sooner"
Richard has the garrett TO4z on his supra in a .82 im pretty sure (not sure if you knew rich) and it was the same response as having the orginal twins setup as a true twin system, not the sequential setup. It wasn't too laggy however that's obviously on a 3L.
Never got a chance to check out his set-up once he got it all sorted :laugh:
Might have to take a stab at the .82 and go from there. (not planning on being up here in NQ for too long so want the car to be good for open circuits in the future)
I am currently upgrading my Single Apexi IHI RX-6 TCW77P25 (makes 300kw on 20psi (lol or 24psi doesnt make any more HP as it cant flow anymore)) and is massively responsive!!! Makes the car very fast around the circuit.
I have gambled and am going for a GT35 .82 rear on a reasonably simple rb26. Will post my results next week. Aim is 350kw on 20psi But I am happy to sacrifice up top for as much down low as possible...
Car is only used for circuit, want to do some hill climbs etc too, which I think I might find it a bit laggy but hell, will soon see....
Michael
Looking forward to the results mate, good luck!
Edited by Tomek
Oh ok that's fair enough. On a more open circuit it does open up other choices than our little tight track :laugh:
Exactly mate, lol...
Either way should put on a good show for the sprint viewers!
im running a t04z in my time attack GTR... 1 bar by low 4k ish, full boost (25psi) around 5000rpm. With an 8800 rev limit, that gives me a fairly wide power band to work with.
Sounds about consistant with the few I've seen do. A GT35R on an equivalent 2.6 seems to get 1bar by 4000rpm and 25psi around 4500rpmish - so everything seems to happen nearly 500rpm earlier on the GT35R.
Im running a gt35r with the .82 housing, atm i have about 400hp atws running 15psi, its getting re tuned this thursday and i will post up both before and after results. If only you lived closer id let you take it for a drive.
hey mate..
looking forward to results.
pm sent
Anna (msnismo) just upgraded from a GT3540 to a T04Z (RB25), being built buy dave (T04GTR) this week. I suggest if you're really having trouble deciding that you shoot Anna a PM. :laugh:
Ash was pretty much spot on with his power ranges though... The T04Z will crack 400kw but will be pretty laggy (expect to spend most if not all of your time above 5krpm) and the GT3540 will be more responsive, but you'll have to ring it's neck to get the kind of power you want (don't think you will get it up to 400).
If you're already set up for twins, I would seriously think about keeping it that way. :wub:
I think your a little off on the predictions there, a 35r will make 400rwkw and more on a properly set-up motor... a t04z is only just getting started at that point.
In terms of response, unique1's t04z on a stroker was roughly equivalent to my 35r with std capacity when we were running similar comp ratio's. In hindsight I would have gone a gt30r or similar, the 35r is too laggy to be quick around ahg or similar short tracks where most of the action is.
Let’s compare apples to apples
Garrett GT3540R,GT35R,GT3582R and 56 trim Billet R-GTV
Compressor Wheel
Inducer 61.2mm, Major 82mm.
Turbine Wheel
Major 68mm, exducer 62mm.
Garrett GT3540R,GT35R,GT3582R compressor map
Billet S62-GTV (ETT)
Compressor Wheel
Inducer 62 mm, Major 84mm + (ETT)
Turbine Wheel
Billet S62-P (ETT)
Compressor Wheel
Turbine Wheel
Major 74.2mm, exducer 64.6mm.
Billet S62 Compressor map
HKS TO4Z, Garrett TO4Z and Billet Z-P
Compressor Wheel
Inducer 66.7 mm, Major 84mm.
Turbine Wheel
Garrett TO4Z Compressor map
Garrett GT4088R
Compressor Wheel
Inducer 63.5mm, Major 88mm.
Turbine Wheel
Major 77mm, exducer 68mm.
Garrett GT4088R Compressor map
Forget fanciful horsepower figures and try and go fast on the track. You can't race a dyno.
Try a .8x GT30 and a bunch of boost.
I reckon even the .82 GT35R will be too laggy for what you're describing.
T04Z is a 440-450rwkw turbo
GT35 is 350-380 give/take
my GTR made 400kw with a GT35 on BD4's dyno yesterday and we neva got to finish tuning it because we had into fuel problems but i was pretty sure a GT35 wouldnt be able to make 400kw as well untill i saw it with my own eyes
im using a .78 divided exhaust housing and it doesnt have any boost control wat so ever but it does come on boost hard
planing on adding another external gate onto the manifold to help with the boost control
What I find more amazing is that you can push 400rwkw's throught the .78 divided ex housing. I actually didn't think it would flow that much.
Good to hear because I'm putting that ex housing on a dual gate divided manifold and running a 3071 for now (on my sr). Least I know I can throw on a GT35 with that housing (albeit machined out to suit the GT35) without having to get a new manifold made up for a T4 footprint housing.
are you coming to SE QLD? As I think (and why I gambled chucking my super responsive apxi turbo) is I think Queensland Raceway will reward HP and a GT35 that is still reasonably responsive and a bigger turbo. Will soon see.... :|
Here is a old dyno graph, crap picture i know, I am not sure of all the mods done to the car but bassically as far as i know its relativley mild. Gt35r, power fc, 600cc injectors, and twin fuel pumps on a near stock rb26
the red line is 15psi and the green is 12psi so i have been told
I will be at a tuner tomorro for a service and a retune.
Edited by el capitan
Here is a few more a bit smaller than the GT35R and Billet R-GTV
Garrett GT30R, GT3076R
Compressor Wheel
Inducer 57mm, Major 76mm.
Turbine Wheel
Major 60mm, exducer 55mm.
Garrett GT30R, GT3076R Compressor map
Billet S56-GT3 (ETT)
Compressor Wheel
Inducer 56mm, Major 80mm + (ETT)
Turbine Wheel
Major 65mm, exducer 56.6mm.
S56 (ETT) Compressor map
Billet S58-GT3 (ETT)
Compressor Wheel
Inducer 58mm, Major 80mm + (ETT)
Turbine Wheel
Billet S58-GTV (ETT)
Compressor Wheel
Turbine Wheel
S58 (ETT) Compressor map
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
    • If you are getting that sort of fuel usage, you might as well be back in the stagea
    • Looks good mate, those stainless lines must be a bastard to do neatly. Better get it to a track again sometime soon, I'm doing to Wakie day next Wednesday to see if the v37 likes cool weather better than hot weather....
    • If you've got spark, and you've got fuel, it needs once last thing to go vroom... Have you compression checked the motor?
