Hey Guys,
I have recently bought and installed and SAFC NEO and was planning to have a shot at tuning it. I have an Innovate Wideband Oxygen Sensor already installed and will be working with this to get the correct A/F ratios. I have searched the forums but can’t seem to find ideal A/F ratios for a Series 1 RB25DET from an R33.
Other relevant mods are:
FMIC
Pod
Manual Boost Controller set to 10 PSI
Turbo Back 3” Exhaust
Copper Plugs gapped to 0.8mm
I suppose I really just need an idea of desired A/F ratios in differing circumstances such as:
Cruising
Under load
WOT low revs
WOT medium revs
WOT high revs etc.
I did try and search but couldn’t pull up anything – if this has been discussed please link me to the page.
Thanks,
Pete
Hey Guys,
FMIC
Pod
Cruising
Under load
WOT low revs
WOT medium revs
WOT high revs etc.
Thanks,
Pete
mate is there any manual how to tune it? i have it as well but have no idea how it works
Thanks Strik3r - are these conservative A/F ratios or are they "right on the edge" so to speak? Should I run it a bit richer to be on the safe side?
Quricha - I have downloaded both manuals from the Apexi Website, and used them to wire the NEO as well as complete the initial settings. I know how to adjust the cells etc., just wan't sure what A/F ratios I should be aiming for...
Thanks for you help so far!
Pete
i'd say they are about what you should be aiming for... Are you sure you dont want to pay a tuner $150 to do it on a dyno ? Then you can observe how they set the AFR's, and tweak the tune on the road.
Thanks for that Strik3r. I'll have a play around with it and if it all goes pear shaped I'll reset it and book it on for a dyno tune. I suppose I am just a diehard DIY'r... :sick:
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
