I know this has been asked a few times but the search didnt really show up alot. I am doing a clutch on an r32 next weekend and will be doing the job with the car up on 4 axle stands. I have taken plenty of boxes out in my time but all with the car up on a hoist at work. How have some people here managed to take out the gearbox? it looks fkn heavy on an r33, i havent yet looked at the r32. I have a pretty good quality blue point trolley jack i was thinking of trying to use. Does anyone know of any hire places that would hire out the floor transmission jacks?
https://www.sau.com.au/forums/topic/24655-r32-gearbox-removal-on-the-floor/
yeah the R33 box was an absolute biatch to put back in and we were on ramps
u should have to twist the box to get it in/out of underneath the car due to the starter motor housing being large so u just cant rip it straight out
im pretty sure this would be the same as the r32 box as they look similar in design
i always do then on the floor with the car on 4 stands , i did the gtr i just use a trolley jack heavy but not hard it helps if u have somei=one to help u though to steady the box on the jack . when i did a landcruiser ( very heavy ) i chained the box on the jack so it wouldnt twist .
robo's i use old input shafts to line mine but u can buy a tool if u want from supercheap or other retailers ( not expensive ).
robo's does u r r33 have a push or pull clutch ? r33 gtr is a pull clutch .
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
